Data and documents are the lifeblood of the business and sharing that data to both external trading partners and internal stakeholders is essential. Discover how GoAnywhere works with one of today’s favorite intranet sites for teams and file sharing: SharePoint.
What is SharePoint?
SharePoint helps teams meet various business needs by providing centralized, secure locations to communicate, share documents, and manage workflows. Like the name suggests, SharePoint is a go-to spot to work together, no matter where you’re working from.
Related Reading: Consolidate Your File Transfers with GoAnywhere MFT
What is GoAnywhere MFT?
GoAnywhere Managed File Transfer (MFT) is a secure file transfer solution that centralizes, secures, and streamlines your data exchange. Simplify your file transfers when you use GoAnywhere MFT to automate regular transfers, comply with federal or industry requirements, or simply keep sensitive data secured in transit.
GoAnywhere MFT’s Cloud Connectors
Cloud Connectors in MFT are integrations that connect your GoAnywhere instance to dozens of popular web and cloud applications. Connecting multiple apps through GoAnywhere allows you to use GoAnywhere as a centralized hub from which to send and retrieve files, much like an iPaaS solution.
Related Reading: Nine Ways to Use GoAnywhere Cloud Integrations
GoAnywhere MFT’s SharePoint Integration
The GoAnywhere SharePoint Cloud Connector integration allows users to securely transfer files between private networks and SharePoint. With GoAnywhere MFT, you can:
- Simplify how you exchange sensitive documents with trading partners
- Manage files stored in Document Libraries SharePoint
- Automate data movement
- Carry out actions in SharePoint from within your GoAnywhere instance
Related Reading: How Azure Works with GoAnywhere MFT
If your organization uses SharePoint as a document management and storage solution, GoAnywhere’s cloud integration can simplify the processes you use daily.
Get the Most Out of GoAnywhere with Cloud Connectors
Discover how you can use the SharePoint Cloud Connector in your organization today.
